astuckey
- Sep 4, 2011
- 83
Hi, I have a Lowe 1436 flat bottom boat. I bought it new, at the beginning of last year, and put a 60 pound 4hp outboard on it. The boat is rated for 15 hp, and it only went 15 mph with the 4 hp, so this year, I decided to upgrade. I bought a new yamaha 15 HP 4 stroke outboard, that weighs 112 pounds, and was more satisfied with 25 mph. I never thought too much about the weight, because the plate on the transom says 15HP max. The boat floats at a reasonable level, so I thought it would be fine. About a week ago, I started hearing a noise, that sounds like small cracks, coming from the corners of the boats stern, on initial acceleration. I took a piece of a hockey stick, held it up to the transom, and sure enough, it was curved. I am not sure if this happened because of the weight of the motor, or if it was the force of the motor, pushing the middle of the transom, and pulling the top. Maybe both...I am not sure. So heres what I need to find out. 1. Is the power/weight combination of the motor too much for the transom? 2. What can I do to reinforce the transom, to solve this problem?
Thanks!
Thanks!
