135 evinrude
crashmouth
my 135 evinrude has no pick up outa the hole. it starts and idles fine. the fuel lines are good (no air leaks) the fuel pump is new. floats are not suck. it seems to be flooding out, and after 20 seconds or so it will plane out. i can help this along by kinking off the gas flow. i havent replaced the needle vavle and seats because pumping the bulb doesnt seem to leak fuel past the neele valve. what do i look at next?
JB
Re: 135 evinrude
Howdy Crash.<br /><br />Look for an air restriction getting to the carbs. Sometimes the noise insulation gets loose and restricts the air intake.<br /><br />Good luck. :)
