130 johnson flooding? plugs wet.
rtriv
I've noticed that my 1995 130 johnson has been smoking excessively. I thought it was the VRO pump, but replaced :eek: it with no change. <br /><br />When the plugs are pulled after even 2-3 minutes of running, they are noticeably wet, especially the bottom 2 which are soaking wet. <br /><br />The carbs were all rebuilt. No change. Idle mixture set. No change. Primer is not leaking.<br /><br />What can it be ? The motor smells really rich when it idles for a while,(5 mins or so) basically gasses the passengers out. <br /><br />Can anyone help ?? :eek:
Dhadley
Re: 130 johnson flooding? plugs wet.
Keep in mind you don't have a VRO pump. You have a fuel/oil pump that mixes the fuel/oil at a constant ratio. If you have a fuel restriction the motor may use more oil. <br /><br />What spark plugs are you using? What oil? <br /><br />Good luck!
