130 Evinrude (96 model)
TxTrukz
Hey Gang,<br /><br />I ran my boat the other day and when I got it in the water it has done this twice now. <br /><br />1. I have to put it in neutral and throttle it to about 3000-4000 rpms to get the water into the engine so that the Tell-Tale will pee. If I don't do that the alarm sounds and I have to let it cool down and then it runs fine. <br /><br />2. The second time I put it in the water and it didn't start peeing, until I put it in neutral and increased rpms and it started to pee and alarm went off. I reversed off dock and tried to take off and motor ran like crap. Turned off engine for 5 seconds re-started, it began to pee immeidateately and Got on plan quickly. Ran fine after that all day.<br /><br />Oh yeah, I just recently had a mechanic put a new water pump and look at it in mid-December.<br /><br />Any advice?
Hooty
Re: 130 Evinrude (96 model)
Was it doing this before the waterpump rebuild? If not, I'd be real suspicious of the rebuild.<br /><br />c/6<br />Hooty
Solittle
Also check the thermostats & pressure relief.
OBJ
TX....seeing where you live, do you run salt water most of the time and do you flush after each use......the motor that is...with fresh water?<br /><br />May also want to run a wire up the pee hole just in case it's got some plugage.
Hooty
Hey, OBJ...<br />Did you make that word "plugage" up? I like it.<br /><br />c/6<br />Hooty
TxTrukz
Guys,<br /><br />Yes, I run in salt water almost all the time and "Yes" I run fresh water after each use immediately. I'll have the t-stats checked and run a wire up the tell-tale. One other thing can you tell me if the engine being a Looper engine makes a difference.....<br /><br />Thanks,<br /><br />Tex
Hooty
Maybe I'm missing something so I'll ask again. Was it doing this before you had the waterpump changed out or not?<br /><br />c/6<br />Hooty
OBJ
I was pulling on a longneck at the time Hooty....you know...."senior moments".<br /><br />I'd like to know about the rebuild to. :confused:
