Biff.McGerk
- Dec 16, 2011
- 14
Hi All,
I have been reading many posts and trying to find an answer to my wiring dilemna. There are many resources out there, but i can't find my exact answer or the diagrams to detailed for me to understand. I was hoping someone can chime in and recommend if i am going about my wiring correctly. There are a couple of different questions i will pose. Thanks for anyone offering help !
1. I know how to wire and connect up my NEW Terrova electric motor in 24v, no problem with that. I also know that i can connect my stereo and fish finders (anything 12v) off 1 or the other batteries as well. The question is is this the correct way to do this? it would probably draw 1 battery down and maybe lead to overcharging or problems in the future, at least that is what i was thinking. i know it will work, but should i be using an equalizer or some gadget that i can draw 12v off both batteries so that they drain equally ? maybe there is some gadget i can get that does this?
2. I heard that you shouldn't run your fish finders off your trolling motor batteries as it will cause interference. Is this accurate and can i go this route? I want to avoid hooking up anything to my crank battery or installing a fourth battery.
3. Previously i had a 12v minn kota on the boat and moved to the 24v motor. The main power plug in the boat is a circular plug with red and black going to it. their are 4 holes(2 on top and 2 on bottom) only the top 2 have the wires. The bottom 2 holes are empty. My question is do i need to change this plug for 24v ?
Thanks very much for the help !!!
