125 forced 1989
Skippy1
Need a diagram showing the linkage from the fuel to the timing the little plastic piece has broke that connects them together with the screw what is this piece
Frank Acampora
It is the link that is used to adjust timing. Most guys replace them with a custom made aluminum piece. Be aware that one of the two blocks is right hand thread and the other is left hand thread. (1/4 X 28 national fine)
Jiggz
No you do not need to remove flywheel to re-time it. Just a plain old inductive timing light. There is a video showing how to do this in one of the stickies on top of this forum. Or you can search it on u-tube.
jerryjerry05
Loosing spark from a linkage change?
CDI ignition has test procedures for checking your system.
Jiggz
Did you re-verify the timing after repairing the linkage? If not, you need to. There is video on the link and synch on how this is done.
