125 force stator question
Mrcaddy
Have a 125 force and i am needing to know what the part under the stator with all the wires coming out is called. Mine has a few bad wires and loose spark at full throttle
sutor623
Good way to check for a bad timer base is to index the flywheel for all cylinders (write the numbers for TDC for each cylinder on the flywheel.) and hook a timing light to each spark plug wire. When you point the gun at the timing pointer on the flywheel ONLY the number for the cylinder that you are connected to should be seen. If you see other numbers show up you have a bad timer base (or a bad switchbox).
Mrcaddy
Timer base thankyou. Problem with this one when you go to wot all spark is lost. Wiggle the wires just so and you get spark again.
Mrcaddy
Part turns out to be called trigger assembly that i was looking for but you got me close thanks again sutor623
