ThomasHill
- Apr 8, 2009
- 34
I'm giving my 120 Hp Mercruiser a tune up. Got new points, plugs, rotor and cap on. Reset the idle and then checked the timing. Man, it is way off. Specs call for 8 BTC and the timing marks are an inch and a half away from the gauge. Went to loosen the bolt securing the Distributor and can't get a socket or a wrench in there. The wrench just dosen't have enough room the turn with the fuel pump and Dist Shaft stopping it. So what tool is used to loosen this bold so you can set timing?
Jack
Jack
