greasemonkey1985
- Jun 9, 2009
- 21
I have a 1989 Bayliner with a 120hp force motor that boggs out, sometimes it will run great and then bog down and others it just boggs down right from the start, it seems to have good spark and fuel, the problem does not change when the primer ball is squeezed leading me to believe that fuel is not the problem, the charging seems low(under 13v) anyone have any suggestions for testing ie. coil resistance test? stator test? other fuel tests?? the spark plugs look wierd, no elctrode/gap, is that normal?? any help is appreciated!!
