120 force motor
mikenjody
put it in reverse and it dies . any ideas i'm new to the boat world thanks
maxum247
Re: 120 force motor
What rpm does the engine "idle" while in "forward gear"? For that matter how does the engine run overall?
max!
mikenjody
Re: 120 force motor
can't get it in forward it dies to. and rpm's are very low .its like its getting no gas any help ????
mikenjody
Re: 120 force motor
the boat is a 1991 bayliner capri ... how do you speed the motor up is there a throttle on it . thanks
maxum247
Re: 120 force motor
Make sure the nuts that mount the carbs to the manifold are tight and check that the choke and throttle valves are operating correctly. Make sure there are no air leaks in the fuel lines and connections to the engine. A rebuilt fuel pump goes a long way too! These are some easy things to check, the fuel pump is around $20 or less to rebuild, if it hasn't been it is a good idea to rebuild it so it does give the proper flow of gas to the carbs.
max!
