120 1992 trim threads
jaba
hey folks!<br /><br />Anyone ever tried to fix threads of tilt pump? Had to change the trim pipe that goes from pump to trim cylinder. When disconnecting from the pump the thread came along the pipe, the owner prior to me had glued the pipe.. Any suggestions, help is needed..<br /><br />-Jaba-
fixin
Re: 120 1992 trim threads
I would think you could tap to the next size and buy a reducer from the local hardware store :p fixin
jaba
That is nearly impossible, the gasket surface might be easily damaged.. well might try that, wont go any worse.. Thanks for the tip.
