Safety Issues<br /><br />12-volts is too low of voltage to give you a shock. Touching exposed 12-volt wires or connectors will cause no harm to people or animals. <br />Wear no watches or jewelry while working around batteries. Large lead-acid batteries can supply enough current to turn a bracelet, watchband or ring white hot instantly upon contact. Many people are critically burned each year by just a momentary contact of their metal watchband or other jewelry across the 12-volt battery under the dash, the hood of their car or in their boat. If that isn't a good reason not to wear jewelry around batteries, the acid in and on a battery may attack and discolor your jewelry. So play it safe and take it off! <br /><br />A 12-volt car/boat battery can supply enough current to overheat wires and start a fire. Never short 12-volt wires together. Never run 12-volt wires in such a way that the protective covering can become abrased or cut so as to expose the bare wiring. Use a flexible wire conduit to protect wires that you add/replace on your boat. <br /><br />Be careful when working around a car/boat battery. Lead acid batteries produce hydrogen gas and can explode if a flame or spark comes too close. Never connect anything to a car/boat battery while the load is connected, this could cause a spark. Disconnect any load and remove the negative battery cable when working on the electrical system. Remember to do the sniff test for gasoline fumes prior to working with the battery or wiring and remove the fuel tank from the boat if you can. If you have a bilge blower, run it, even if you don't plan to start the engine to clear the compartment of fumes before going to work.<br />Since some still choose to use batteries with fill caps and not the maintenance free type.....<br />Be sure your battery is in an enclosed battery box to protect your boat from battery acid leaking from the battery as well as covering the battery posts so that accidental contact can be made with the battery posts. Attach the battery box to the boat so that the battery can not turn over or shift.<br /><br />Keeping a battery fully charged when the battery is not in use will prolong the life of your battery.<br /><br />Please add your ideas and experiences too.
