thomasiam
- Jul 1, 2013
- 30
hi guys.
BTW thanks for all your help and guidance in modifying my new 12' porta bote to handle a 9.9 HP motor.
here are some mods i did for the past few weeks. the original design was done by Stepperbill plus my own add ons.
first and foremost issue was beefing up the transom to be able to handle the weight and thrust of my new 9.9 hp motor.
to do this i got my hands on pourable structural foam and filled the transom cavity. simple two parts mix and pour into the holes i made on top of the transom. it's a closed cell foam.
after that i got some 1/4" aluminum to make the transom support.
the cross "L" bars are welded into the back plates and bolted through the transom.
I added more bolts to the side support. so total of four on each side where the transom is attached to the boat.
lastly i installed a square bar under the seats from bow to stern. the bar was fastened using "closed fastener".
i'm ready to hit the water this weekend i think.
i'm not sure if i want to install U beams on the floor of the boat since that means making so many holes to install it. will see.
