12/24 Trolling Mtr wiring
j2jdoug
I have A 1996 Cobra bass boat with a three bank charger. Want to make sure I have the trolling batteries hooked up correctly for 12/24 operation. 12/24 toggle switch is located on the foot pedal of my Johnson BFL4TS trolling motor. I have six wires coming out of the hull to the two deep cycle batteries. Red, Orange/red, black, black with purple stripping, The other two blacks have a small red and black coming out of each wire, assume these should go to each battery for charging?
Also want to make sure I have the wiring connected correctly in the head of the trolling motor. I had to replace the plastic gear in the top of the trolling motor and not sure if I have it wired back correctly. Picture of wiring diagram would be helpful.
Thanks ahead for any help, J2J
alldodge
Re: 12/24 Trolling Mtr wiring
Here is some info and hope it will answer your questions
http://ww2.justanswer.com/uploads/G...v_tm_plug_batt_wiring_w_run_charge_switch.jpg
http://forums.iboats.com/electrical.../wiring-batteries-series-parallel-225494.html
http://www.motorguide.com/userfiles/file/Accessories/BatteryChargers/battery-charger-manual.pdf
