I noticed on my last trip to the lake that my trolling motor ran the same on 12 volt as it did on the 24 volt side. When i got home i checked all my connection on the batteries and my 3 bank on board charging system. I found that my charger said i had a bad connection on one battery,but no matter what i did it still showed a bad connection and that bank wasn't charging,but before i done that i checked the trolling motor and it ran the same on 12 or 24 volts but after i cleaned the connections i noticed that while running on 12 volts and switching to 24 volts the motor would almost stop and ran very, very slow. could this be a bad switch or is something else going on? I would appreciate any help.
