verdebimmer
- Jul 3, 2013
- 5
Been looking through the forum posts for a few weeks and never found a similar problem to mine. I am hoping that someone here has some insight into my problem. Boat is new to me and had the problem since I got it a couple months ago. I got it so I could take my 92 yo parents out on the lake. I figured this wasn't a big problem, since the boat ran great above 3000 rpm. I was wrong.
Motor starts well and runs with minor shaking until it reaches 2000 rpm. Doesn't stall even when idling at approx 700 rpm in gear. Running along at 1000-2000 rpm seems to surge and vibrate a little, like a cylinder sometimes misses then occasionally fires with minor shaking/vibration. Then, when accelerating it shakes pretty badly until it gets to almost 3000 rpm. The shaking is pretty severe, depth finder really shakes in its bracket! Above 3000 rpm until 5100, it runs great. Since the motor is installed on a pontoon boat, I would like to run in the exact rpm range where the problem is worst. I have checked compression (120-125 all cylinders), timing (0 degrees BTC at idle, 28 at WOT), champion plugs are new (0.030" gap). The idle timing screw is screwed all the way in, so I can't advance the idle timing any further as I think it should be 4-6 degrees BTC. I had a local marina check it out. They told me it was a carb transition issue, where it goes from low speed jets to the high speed ones. They did a link and sync, removed/cleaned/adjusted floats on carbs and checked timing and said there was nothing else to do.
I've since checked all the resistances of the coils, power packs and stator that I can do with a digital VOM. All were in spec, according to factory manual. I also switched the power-packs from port to starboard, which made no difference. After all of the above, I checked the port side plugs and noticed they are very clean compared to starboard, like they are being flushed with gas making me think they are not consistently firing. I then ran the motor with #2 (top, port side) plug wire disconnected and had no vibration, although WOT throttle rpm was only 4100 rpm.
So, I'm guessing there's a low rpm ignition issue. From what I've seen on these forums, usually there's a problem at higher rpm, not lower. Can anyone please give me some advice?
Thank you.:cold:
Thank you.:cold:
