115hp Turns over but wont start!
djs151
I have Chrysler 115hp. Engine worked perfectly until last weekend. Engine started to bog out, returned to wharf. Engine turns over but wont catch - sounds like battery doesnt have enough power to start engine. Pulled boat out and boosted with my truck, engine started after spraying some gas in carbs. Dropped back in water and left for a few hours. Returned and tried to start, rolls over but again sounds like battery doesnt have enough juice to start motor. Bought new battery - same result. When i did boost the engine and it started, it did not run well at idle and would stall if i didnt give it some throttle. Any help would be much appreciated!!!!!!!
roscoe
Re: 115hp Turns over but wont start!
So many possible things going on here, gonna have to narrow it down some.
Check the engine compression. You can buy or borrow one from most auto parts stores.
Then check for spark on all cylinders.
AlanR
check compression, Clean carbs
