Kloctower
- Oct 17, 2016
- 60
What should my amps be on my rectifier? I ordered a new rectifier from two different companies with the part number that specifies on Marine engine dot-com and other sites. I found the numbers listed in the catalog as well and i order the part but they will not work. I believe they are not the correct amps. the book from my motor says its a 6 amps system and rectifier but I cannot find the information on the rectifier on the sites that sell them. they do not list the amps so I'm not sure what I need and where to find it without buying a third rectifier that's the wrong amps. They cause the motor to do weird things. When I install the wrong rectifier it causes the motor to act like it's has a limiter installed. It can't get to WOT. Install the old one with cracked wires and it takes off perfectly. Repeat process same results.
