115A fault code
muskrat
I have a 115 TLDI keep getting tps 1 fault code.Motor has 1500 to 2500 hours use it for crabbing.Battery two years old cca800 & bolted down termials.Motor has ever been any trouble were do i start.Thanks
pvanv
Re: 115A fault code
Are you in the 3+1 year warranty? If so, a dealer can help. Did you reset the TPS per the Factory service manual? You need a bigger battery; 1,000 cca. If the problem persists, and is a "failure in TPS #1", you may need to re-seat the connector, and/or replace the tps. If it's just a "wrong position of tps 1", the reset should clear the error.
TOHATSU GURU
Re: 115A fault code
Chances are that you have low voltage from a marginal battery or connection. That causes the sensor to require a re-set...The correct procedure is to take it into a dealer for a diagnostic or get a factory service manual that gives you the self test procedure and the fault codes.
muskrat
Re: 115A fault code
Thanks just trying to get a little back ground on this unit.
muskrat
Re: 115A fault code
Up date bad wiring harness bottom plug.You can hold the harness tight against ecu and no problems.
