Hi all! I'm new here. Here's my question. I have a 2003 Mercury 115 Four stroke. I ran on to a sand bar today and sucked up some the sand and shell. I got the boat off the sand bar and started the motor and moved to a safer area to investigate any damage. The warning buzzer sounded during the move and I shut it down. I set out the anchor and let it cool down for an hour. I restarted it and notice I had very little water out the pee hole. I went ahead and started back to the dock slowly. I noticed water out put from the pee hole increased and I felt all was good. I made a 2 mile run with no issues. Then I took off to another spot with no issues. I fished for a few hours and then when I was making my way back to the dock the engine overheat buzzer went off and I shut her down. While I was waiting to get a tow I started the engine and notice that there was no output from the pee hole. When I got the boat on the trailer I hooked the hose up to the back flush connector and flushed the motor. I hooked up the ears to the water input on the lower unit and ran the engine for around 10 minutes with no issues and good water output flow.
Is there anything I need to do with the motor like change the t'stats. I feel I need to replace the water pump but I am not sure if I need to do anything else.
