115 johnson yr. 76 miss problems
attack
fuel system and carb totaly redone<br />motor still has a small back fire<br />plugs new,high tension wires good<br />could it be the stator?<br />please advise direction to go<br />oh compression good.<br /> :confused:
almost retired again
Re: 115 johnson yr. 76 miss problems
Hi Choas,<br /><br />Back firing is usually caused by a cylinder not getting spark at the right time. Are you sure that the wires from the power pack are going to the right coils, or are the right coil wires going to the right plugs? If it's back firing and not just caughing then that's where I would start.<br /><br />Let us know how it comes out
attack
IT IS MORE LIKE A COUGH, OR A SPUTTER<br />ON THE WATER WHEN GIVE IT FUEL IT DIES<br />IF I GIVE IT FULL THROTTLE I CAN GET IT TO GO<br />BUT IT ACKS LIKE IT IS STARVING FOR FUEL, IT CLEARS UP AT HIGH RPM. BUT RETURN WITH LOW TO MID RANGE RPM. ALL MY CONECTION ARE CORRECT. IS THERE A WAY OF CHECKING FOR SPARK IN EACH CYLINDER WITHOUT A SPARK TESTER - WITHOUT DAMAGING ANY THING? PLEASE HELP WITH A DIRECTION TO GO
attack
Sorry about the caps I will watch it in the future<br />I do apreciate the help and don't want to make any body angry
