115 Johnson help!!!!
BASSCHASER007
I have a 115 Johnson 83 Model number JS982723. Runs great once it's started, the problem is getting it to start. It did start great with no problems , then I took it out one day and it wouldn't start. I thought it was plugs so I changed them,no difference. Normal starting proceedure would be lift idle handle, or whatever it's called, push in key to choke engine and crank. Now if I lift the idle handle and/or choke it it will not crank, and will only crank by turning it over for a extremely long time. Checked carbs but didn't rebuild them because they looked in excellent condition, no build up.
adrian bick
Re: 115 Johnson help!!!!
Pump up the primer bulb and hold key in while cranking to start that model.
BASSCHASER007
I've pumped the bulb tight, and check it after trying to start it, it stays tight. I've pushed the key in to choke it and <br />it doesn't help.
