115 Johnson; Got no power, please help
Backroads101
I'm having problems with my dad?s 2006 115 Johnson. The motor sat for three years and started working on her. I rebuild all four carbs; set them to factory spec. drain all the bad gas, ran sea-foam. Check all the cables. Water pump is good. I have a feeling that there's a bad fuel line, that going to be replace. But other than that, I'm stuck. She quits every time I go to throttle down. One thing I have notice, when I rev her up, she won?t die, but soon as I put her under a load, she will go into the come out of drive and quit. I can watch the motor do that every time. There enough power to get the bow up but not on plane. Any idea or suggestion would help.
Thank you
H
1983 ercoa 21'
I'm not real familiar with this motor but a good starting point would be a cylinder drop test to make sure all cylinders are hitting.
id also do a compression test.
