115 HP Merc won't stay running when cold
jedlkn
1987 Merc needs about 10 minutes of warm up before it will run under load. If the engine idles (even fast) for only a couple of minutes when I hit the gas then engine will bog down and die. Carbs have been rebuilt. New plugs. No sign of water in the gas.Enrichment valve will feed fuel when engergized. Once the engine is fully warmed up it runs fine.
