Nandy
Thread starter- Joined
- Apr 10, 2004
- 2,145
I moved a 1974 115 hp evinrude with a 13 1/4 17 pitch to the cobia. I used to get 30 mph with up to 4 adult in the boat with the 1975 70 hp evinrude. With the same prop. The 115 is giving me just 4 mph more and the wot rps are 5200. This is very frustrating as I was hoping at least be in the 40 mph. However, I get in plane super quickly and way lower rpms. I can feel a big different in the power, just not the speed I thought... This boat should be around 800 lbs. I have a few things to try but I am looking for any further advise.
This motor check out good for compresion and had spark in all 4 cylinders. It sat for quite a few years with no gas in the carbs and started and idle great at the first try. I need to check the following.
1. Check if the thortle is really wot. I just move the motor. I kept the control and cables from the 70. I did adjust both the thortle cabld and the shift cable but I need to double check it is open up.
2. Do a decarb.
3. Check the link and sync.
4. I can probably raise the motor an inch, maybe that will do the trick...
Anything else to check?
Thanks!!!
2. Do a decarb.
Thanks!!!
