As the title suggests, I have a 1975 Johnson/Evinrude and I am trying to remove the lower unit to change the water pump. I have already removed the 6 bolts holding the thing together and disconnected the shift rod, so the thing should just slide right off. Unfortunately the lower unit is stuck tight. I tried jiggling, "coercing" it with a mallet, turning the engine, even using some steel shims to try and pry it apart, but nothing's moved the lower unit more than 1/4 of an inch.
I have gone over the manual 5 times already and I haven't seen any bolts or steps that I've missed. The unit must have a corroded spline or linkage somewhere. Any thoughts? it would be a shame to see this engine scrapped after so many years of service.
Thanks in advance.
Thanks in advance.
