115 Evinrude crank interchange?
drackley
I'm starting a rebuild on a 1994 evinrude 115 inboard (Seaswirl Squirt with a jet). I need a crankshaft and have an oportunity to pick up a 78 V4 115 crank new for a good price. My research shows that a rebuild kit may cover back to that vintage. Can anybody enlighten me on crank interchange for this 115JEER.<br /><br />Dirk
clanton
Re: 115 Evinrude crank interchange?
The part numbers are not the same for 1978 and the numbers do not chain in the price book.
Hooty
Won't work. Different crank.<br /><br />c/6<br /><br />Hooty
dpminc
The 93 and up 90 degree v4 cranks have a removable wear sleeve at the PTO end. The seal part# is the same, and splining is the same, 78 should have the big center main. May work, but I havent tried. I do know the looper v4 cranks had a similar change in 93, and will interchange with each other. This is anecdotal though, as I havent tried this with the crossflow motors like yours.
Dhadley
Yes you can get around the issue of the different bottoms on the cranks but the 78 has a small center main and you need one with the large center main. <br /><br />If you cant find one let me know, I may have the one you need.<br /><br />Good luck!
