110 evinrude outboard not running
horse
Wow - there are alot of postings<br />I hope I get a response - I am a first time poster.<br />I have a 110 evinrude outboard - it is not running<br />I have had the carbs gone through<br />It seems to be a spark problem.<br />THough I checked teh spark at each plug and have spark. it will run for 20 seconds and quit.<br />could it be a spark problem if I have spark when I test it - what could it be<br />I am a bit unknowlegable on outboards<br />thanks<br /> :(
Joe Reeves
Re: 110 evinrude outboard not running
Horse.... What is the model number of that 110hp? We need to know the year it was manufactued.<br /><br />(Compression & Spark Test)<br /> <br />1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi.<br /> <br />2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame.<br /><br />Let us know what you find in the above areas.<br /><br />What starting procedure are you using? Pump the bulb hard, arrow facing engine? Pushing the key ion to actuate the primer solenoid? Spraying fuel into the carb throats? Give us some detail.<br /><br />Is this engine new to you or have you owned it for some time? Did you manually clean the fixed brass high speed jets? If you remove the bottom side screws from the carb float chamber, does fuel flow out of them when you pump the fuel primer bulb?
bonitoman
I have an 86 110 you can email me jsapo@cflr.rr.com I have rebuilt my engine and have changed every electrical part over the past three years. I fish every week here in cental florida.
horse
Thanks for the response<br />Joe<br />*I will do a compression check<br />*the engine is an 86 I will find the model number<br />*I have run the boat alot for almost 3 years before this prob popped up<br />*I will also do a spark test.<br />*I had the carbs gone through I did not do it myself.<br />*THe mechanic has not had time for it for a couple of weeks. - I got impatient so I am trying to trouble shoot myself.<br />* need to find a Manual for it.<br />thanks
horse
We ended up having to replace the entire wiring harness (the part that hooks up with a big 5-6 hole plug to the wire that comes from the dash.<br />there were several of the wires that were burnt completely through - I assume that the wires had gone because they had gotten worn through a bit and then they had gotten when when the water pump hoses started to leak.<br /><br />I took the boat out to Jordanell Res in Utah (Heber area) on saturday and it ran great. I am still amazed at the performance of that evinrude 110. it is matched just right for my 17'boat. it went great and ran good....<br /><br />Looks like we will run it for a while.<br />OH - I was also pleasantly supprised at the cost of repair - to have the carbs gone through and have the wiring harness replaced and have the lower gear oil changed and some additives put in the gas = it was only 300.00. I was real happy<br />signing off.............
