kbait
- Nov 13, 2007
- 2,481
qd-20 10hp, pressure tank system. Great spark, good pressure tank system and fresh fuel. Primed carb w/primer on tank and it starts fine, but dies due to starving out of fuel (sneeze). Even at higher rpm's than idle, where the low speed side wouldn't matter if it were clogged up (it should stay running). If I primed it again, it'd start again, and die after about 4 seconds. I then cleaned the carb (yes, all passages.. set the float even w/carb body, etc. Opened the high speed jet 3/4ths turn, and low speed 1.25. Hooked it back up and same result. Pressure builds fine in the tank, and it'll stay running as long as I push the primer, but dies immediately when I stop pumping it. Kinda got me scratching my head, as I've worked on these for years, and this is a new one! I'm sure it's not spark, and compression is good. Thanks!!
