Re: 10hp evinrude what oil and gas
Hi DSK,<br /> The 10hp Sportwins were built in one form or another up into the early 1960s (need model number to pinpoint) and don't make the cut for 50:1 mix. They still had several bronze babbit bearings and need some extra oil to stay in operation over the long haul. 32:1 (pint oil to 4 gallons gas) using good quality TCW-3 rated oil and good quality gasoline (89 should be good enough - 87 can be kinda junky in some areas, 90+ high test not necessary) and you'll be good to go...<br />- Scott
