100hp & 115hp johnson's
likearock
hi all,<br /> i have both a 100hp and a 115hp johnson outboards. the 100 is a 1979 and the 115 is a 1977. i was just wondering what the major differences were between the two? are they the same bore and stroke?<br /> thanks again, LIKEAROCK
Big Rod
Re: 100hp & 115hp johnson's
Same bore and stroke, exhaust improvements and carbs.
mbb
I had a 79 evinrude 100. IMHO Best motor ever made. Put around 2000 hrs on my motor between 79 and when I sold boat in 91, never cleaned a carb, never decarbonized, changed lower unit oil once, and water pump impeller once. It just ran. A bit finnicky to start in morning, but then would fire as soon as you touched the switch all day. Was a bit of a gas hog too at WOT. Wish they still made motors like that one. Bet its still running today.
adrian bick
Major difference in the centre crankshaft bearing.The 79 V4 blocks got the same bearing as the V6, The 77 had a much smaller bearing.
