I bought a 1968 1000ss yesterday. I bought it pretty cheap for a project motor as it ran ok,
BUT...
The shifter would shift into neutral when shifted towards reverse. Otherwise it was in forward gear.
I thought that maybe the selector shaft might be out of time-no big deal. After 2 hours of screwing around I came to the realization that the shift shaft coupler splines are worn out. The shift shaft only engages about less than 1/2" of the selector shaft coupler and they are about gone.
When I line everything up and then shift it it just skips a tooth or two and doesn't work.
Is this a fairly common problem?
I think it is a 47326A1 Shift shaft. Coupler 93960A1??
Does this thing screw on or???
BUT...
