10 hp trigger coil
pontoon chief
Have a 10 hp ,1995 merc with no spark.Using the service manual is pretty basic,but short on information.I am looking for the spec on the CDI box so I can ohm out the unit.CDI box is not in the manual except removing and replacement.Does anyone have the test out procedure?
I attempted to test out the trigger coil,but have a question about the use of the meter.
When I hook up the meter to the Br/y and the Br/w leads on the trigger coil the meter at first reads a number from 38.7 low,to 44.3 high.That number drops off to 0.0 after a second.According the the manual,that number should be Res,650-850 ,6.5-8.5 RX 100.
Should these readings remain static,or should they drop off as they do?
