08 115 Mecury Optimax Skeg Repair
ctoshack
Does anyone know what size and where to get a replacement skeg for this motor it is the 3 cyl 115 optimax.
I do not want the skeg guard thing you bolt on I want the correct aluminum skeg that needs to be welded on.
Also does anyone know if this can be done with the techno weld aluminium sticks that use low heat from a regular torch. You can see them on youtube.
Faztbullet
Re: 08 115 Mecury Optimax Skeg Repair
WSM and I think its the SK-16 skeg..
No way... needs to be professionaly welded
j_martin
The skeg is the only rudder your boat has. If it fails at high speed, bad things happen, and very quickly.
