jason4027
- Aug 31, 2009
- 9
I recently purchased a barely used 07 208 LXi with 13 hrs on the meter (now has 24hrs) and have some questions that I can't find answers to in the manual.
#1 - Original owner said the transom shower was hot water, I have discovered it is just fresh water from the lake and not hot or warm, has anyone tied a tee into the hot line after the thermostat on the engine to add some hot into the mix to make it warm. May have to put a valve in to add just enough hot when engine is running?
#2 - The digital depth sounder works great but has a temperature option as well but does not work. Was this an option I don't have? I think it is supposed to alarm beep when shallow water is detected(I have it set to alarm at 5') but no beep just displays shallow water alarm. Where is the depth sounder and temperature sensor located? All I see on the hull is a 2" round plastic screen covering the inlet for the transom shower under the leg near the drain plug.
#3 - There is a buzzer thats screams when the key is turned on when starting, it warns you of low oil pressure, I like the option but is very loud and annoying. Is it built into the gauge? I can't seem to locate it. I don't want to disconect it but wondering if I can shove some tissue in it to make it quieter?
#4 - It has a Clarion CMD4A head unit that will work with iPod CeNet Controller. I have looked on the internet for the cable I need to attach to the iPod but I read that it does not work/control the Ipod Touch or iPhone. Has anyone tried a touch/iPhone with theirs? I would like to use it but don't want to waste the money buying the adapter to find out it don't work with my iPod.
I know this is a lot of babbling but I am frustrated with the owners manual, it is very weak on info. Does anyone know where to download a service manual? Maybe there is more specific info in it. There has to be better info out there for the techs that work on these boats.
Thanks
Jay
Thanks
Jay
