Starts right up cold using fast idle lever. Takes a while to warm up. When fast idle lever is lowered to shift into gear, engine dies. Trying to restart results in flooding of 3 of the four cylinders. It floods so much that you can smell gas and it streams out of a small spout on the bottom of the plastic cover just in front of the carbs. Also, when warmed up water exits a small plug above the carb that has a disc pressed in but a drain slot in the side of the plug hole. It looks like a freeze plug but with the slot in the holder it can not be water tight, at least that's what it looks like to me.
Any help would be appreciated. Bonus points for correct answers.
Thanks in advance.
PS. Previous owner included a work order for $2,000 worth of various engine work including working on the carbs. Unfortunately that mechanic is 1,000 miles away
Thanks in advance.
