Re: 05 Evinrude 115 - 24 Foot Tri-Toon: Prop???
Must be a leftover 04; 05 was etec production,no 115s.It seems to me that a tri with a 115 should do lots better. A 13 is a good size for most 115s.
At least 25 and 30 is possible.Of course log size and boat weight and build vary.Maybe you could raise the motor a little.Check that the throttle opens all the way.Maybe water in the logs? Is the prop in excellernt shape?
