OK I had a problem with my motor only cranking when I would turn the throttle wide open, and when I would get it cranked it would top out at 52 mph gps, it usually should go 58 in that situation. I brought it to the shop and he cleaned the carbs and replaced three cdm's and got it going. He told me it would crank and run 5800 rpm now. Well I took it out today for the first time and it is idling at 1100 rpm in neutral and won't get above 5000 rpm, which was 52-55. It didn't run bad it just won't get to 5800 like it would before. In the same situation as today it should go 58-61. Any ideas ?? Thanks.
