deadmerc52
- May 1, 2011
- 6
I just got a 25 HP merc that was supposed to run fine. 2 stroke, single carb with good compression and what looks like good spark at the new plugs. Lower cylinder is dead at idle and it comes and goes at higher RPM. Plug is dry and cool and it does not blow back through the carb. Also, there is a lot of gray foamy goo at the prop exhaust. . Any help on what to check would be appreciated. Thanks
