04 johnson 115 tilt trim issue
Evilrude
Yesterday my tilt trim did strange things. Worked fine until it didn't want to go down. Then later it did go down and up just fine then it didn't want to go up ??? After a bit it decided to start working fine again up and down??? Very confusing I pulled the relays off to see if they were corroded but they look great . I tried to check my H fluid and it poured out a little so I guess it's full. ??? Any help is much appreciated. Also when the up and down didn't want to work it was separate occasions and when you pushed the button you could not here anything ? Thanks
