'04 50 hp cooling problem
aau10
I put the water muffs on and started engine but got no water flow. Engine temp alarm sounded so I shut engine off. The engine hadn't been started for about 9 months. Any ideas as to what the problem could be?
aau10
'04 mercury 50 hp 2 stroke cooling problem
The motor had not been started for 9 months until today. I put on a set of muffs and it started right up but water was not going thru the cooling system. The temp alarm sounded so I shut it down. After cooling off I tried it again. This time water was flowing thru it but if the pressure was lowered on the supply hose the flow thru the motor went down also. I then tried it with the foot in a tank of water to see if it would work. I got some flow but not enough to keep it cool. Is my problem the water pump and or the thermostat? Any help appreciated.
Barnacle_Bill
When is the last time the impeller and thermostat was changed? If you don't know they are past due.
