Bought a used boat with this motor on it back during the summer. First time I took it out no problems throughout the day. I had my mechanic put in an inline fuel filter and an hourmeter and changed out the plugs. Engine has maybe 60 hours on it. Compression test prior to purchase was all around 110.
The problem only occurs later in the day. I can choke the motor and crank it easily for a carbed motor first thing in the morning. Run around to three or four spots, and then it happens. Usually after 11:00 or so. No matter if I put the engine in gear or are simply idling in place, the motor dies out in 8-10 seconds (it cranks easily just prior to this occurring).
I have to then work and work with choke and throttle to get the engine running again. At this point, it is running rough, vibrating the boat. As I told my fishing partner, I think there are two raccons chasing each other underneath the cowling. I will place the motor in gear and it will rough idle up to plane with a moment or two of hesitation and once on the top end will run like a champ.
I suspect maybe varnish or other problems with the low end jets. The previous owner had filled up once back 4-5 months ago, but swears he used stabilizer when filling up. I have since went through 1 1/2 tanks myself. The primer bulb is firm prior to starting each time. I am just at a loss as to what is causing this.
Thanks for your help.
