murkywater
- Jun 11, 2007
- 6
I have a 2003 boat with two Volvo Penta 5.0 GL-C's w/Holley double barrel carburetors. One of the engines will not stay started. Starter turns, engine fires, but cuts off as soon as ignition key is released. The perplexing thing is that every once in a while (after several days of attempting to start) it starts and runs fine for hours. Then, it will not start again after turning off engine. I have checked the fuses, wire connections, spark plugs, relays, ignition switch, kill switch, and alternator. I then switched to other fuel tank and drained the fuel filter thinking that the problem may be in the fuel system. Any clue what may be causing this?
