I have a 2003 90hp Johnson and they say my fuel pump might be out, but not sure. Said it's cheaper and better to go from oil injection to mixing the oil with the gas and installing a different fuel pump as the one for it now costs $450 because it's oil injected. He states that if I change over and use mix, I would have less a chance of burning a piston down the line as it's typical in oil injection if they get plugged and no oil gets in the cylinder. Truth to this? Would you convert over? Is there anything else that could go wrong or I need to address if I change to mix? Do I simply pull the oil resivor and lines out then? Will this affect the motor in any other way? I know, alot of questions, but I don't have aclue and would like some advice! Thanks
