The gauge is pegging with ignition on/engine off. Starting the engine, there's a small movement, but still shows 80psi.
I was going to check the wire(s) at the switch to see if there's a ground issue.
Where is the switch located on this engine?
Is it accessible from above? (Sea Ray 230 BR...pretty tight in there)
Thanks!
JP
Thanks!
JP
