Sea_Slueth
- Apr 17, 2004
- 10
I purchased two new 2002 130 engines.<br /><br />The serial numbers on the silver plate that are visible (w/o taking hood off) on the starboard side of the engine are BZBH 1300*** series and BZBE 1300***. <br /><br />I was told that these were after the cracked block issue.<br /><br />While doing some minor work on my engine today with the hood off, I noticed serial numbers<br />on the valve cover. I believe this is the name.<br />It stares you right in the face as you look at the tail end of the engine.<br /><br />These serial numbers start with BEBE 1016*** and the other engine has BEBE 1018*** series.<br /><br />I am now concerned and am curious if the engines are mixmatched and the heads may have the crack issue......<br /><br />I purchased them new in April 2002 and was told by a Honda service center that the engines were not subject to the head issue as their serial numbers were in the 130 series.<br /><br />Thoughts?
