02 200hp Merc- Someone has to know
DBVentura
Ok. I have a small diameter gray tube coming from the lower rear section of the powerhead to the front of the engine. It is wire tied in place and goes no where. When I started the motor for the 1st time this year I noticed water pissing out of it, it looks like it used to go somewhere but visually I canoot
find out.
saumon
Re: 02 200hp Merc- Someone has to know
If water is shooting out of it, it probably used to be connected to a water pressure gauge at the console and this tube was cut for an unknown reason, maybe an outboard or powerhead swap.
gss036
I think you hit on the head w/ your answer on the pressure gauge line. Follow it back up and see what it is connected to. Then plug .
DBVentura
Thanks guys. I'm going to plug it. By the way the end looks it was connected
to something sometime.
DB
