01 XLT Backfire
Rockit611
I tryed to start it up today...It tryied to run but backfired & stalled...now it just backfires, won't run..I put new reeds & a stuffer kit 3 months ago...could it have jump timing?
Jeff Walkowiak
Re: 01 XLT Backfire
check compression,, and be sure the reeds are working properly, does fuel blow out the carbs
Rockit611
Re: 01 XLT Backfire
Compression's good 120 in all cylinders... i'm not sure about the reeds ,I gota pull the carbs
Rockit611
Re: 01 XLT Backfire
I talked to another guy..thinks i might have broke the key on the flywheel
ragu
Re: 01 XLT Backfire
Did you have the carb off ? If so check the gasket between the carb it could be sucking air
bamafutbal
Re: 01 XLT Backfire
the xlt is the worst for carb repair, lotta stuff to take off. just had mine rebuilt
