01 GX185 SF overheating issues
kscharf
Before i take the boat to the dealer i was wondering if anyone had some advice...
I put the boat into the lake for the first time tonight, and being April, ice out was yesterday on Lake Minnetonka, anyways, i made it a mile from the launch and my temp guage ticked past 250 and the heat warning beep came on. I shut down, let it cool, and restarted, just idleing it went from 150 - 250 in 30 seconds or so. I get back to the launch and checked the obvious, intakes, oil, etc.
Im not very familiar with the cooling systems on boats, but i assume its the water pump that failed, what else could cause something like this?
Also, is there a antisiphon mechanism on the glastrons?
Thanks
Kyle
ziggy
Re: 01 GX185 SF overheating issues
usually the first place to go look for an overheat condition is the impeller in the lower unit. the seawater pump.
most new boats have a anti shiphone valve.... i think is a uscg reg. that it does....
Don S
We need to know what engine and outdrive you have to answer specific engine problems. Type of boat doesn't matter at all for engine and drive problems.
kscharf
Engine is a GM 4.3GL, Volvo Penta Outdrive
Don S
Your raw water pump is mounted on the end of the crankshaft pulley, not to be confused with the engine circulation pump (aka a water pump by automotive types)
The raw water pump is what sucks up the water thru the drive and delivers it to the engine and exhaust system.
I suspect that my raw water pump went bad. Can I tear it down and just replace the impeller or do I have to buy a whole pump??
How do you test the water pump?
Don S
Welcome to iboats RC, Best to start a new thread with your question.
It's bad form to hijack someone elses thread with your questions, plus it gets real confusing wondering who is answering who.
