0 compression #4 cylinder Mercruiser 5.7 1988 Rinker
Donbaycity
Overheated, replaced thermostat, changed oil and plugs. Plugs all looked just burnt, no water in cylinders and oil looks fine.. Any ideas. Appreciate your time..
time to perform a leak down test to determine if the issue is valves, head gasket, or piston/rings
tpenfield
Let us know what the other cylinders were for compression. 0 psi is not good. :eek: Tell us a little more about how the engine was running, etc. before the overheat and anything that may have caused it to overheat.
